Spark Plug Wire Assembly
Old May 11, 2005 | 11:57 AM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
Is it OK to use something like dish soap in small amounts to lube the wire so it can slide into the distributor boot? Assembling accel wires...
Old May 11, 2005 | 12:26 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
di-electric grease, most wires come with some
Old May 11, 2005 | 01:12 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
Don't have any... no yes/no on the soap?
Old May 11, 2005 | 02:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No
Bad idea
Dielectric grease
Old May 11, 2005 | 02:04 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
doh
I take it that could be a reason a car wouldnt start then? I did it on a different car (that wont start now) , and i was gonna do everything the same step by step on my tuneup to see where i went wrong... Could i unassemble the plug wires and wipe it off/redo it with dielectric grease?
Old May 11, 2005 | 02:11 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
First double check the wire placements. Make sure the firing order is the same (1-8-4-3-6-5-7-2 on a SBC) and that you didn't get off a position on the cap.
Did you do them one wire at a time, or pull all the wires at once?
Have the cap off the distributor for any reason? Or the distributor out?
Old May 11, 2005 | 02:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Soap probably wouldn't keep it from running, right away; but it's corrosive (to the wire itself and the connector), and it attracts moisture. Definitely not what you want around plug wires.
I think you can get a little packet of the right stuff for like 99¢ at AutoZone.
Old May 11, 2005 | 03:18 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
I did it one at a time, i tihnk the battery may be low and need a jump to give a strong enough spark. All i did was plugs/wires... This engine does not have an external coil, its a "goodwrech 350" it says on the side, gotta love workin on crate engines in other peoples cars. But I should be able to dissasemble the wire, wash all the soap off dry it thouroghly and then put some of the right grease ona nd it should work peachy, correcT?
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
