How do I hook-up a mechanical gauge to check my oil pressure?
Old Aug 16, 2001 | 09:00 PM
88 GTA Notchback's Avatar
I think my oil pressure sender is finaly flaking out on my. How do I hook-up a mechanical gauge and check my oil pressure?
The car is an 88 GTA with the L98 engine.
Thanks,
Jacob
88 GTA Notchback
A4 / 350
Stock
** New User Name**
Kill List:
95 Mustang GT |88 Mustang GT
94? Impala (real close)|97 Dodge Neon
86 Corvette |2000 Prowler
88 ASC GTA | And a few more Accords and Neon's.
And more Civic's then I can count. Why do they even bother?
Old Aug 17, 2001 | 12:51 AM
SHE DVL's Avatar
Do you want to check it, or permanently mount an aftermarket gauge? There's two easy places you can check it on the engine. The first is right behind the intake near the distributor on the block. There's a little plug in that you remove and screw in the sender line there. Or you can screw it in in place of your oil pressure sender, which is the sensor right above your oil filter. If you just want to check it then you don't even have to hook up any wires to the gauge. If you want to permanently mount it, then you have to hook up wires to it to make the light work. Also I'd advise that you use a copper line on the gauge if you plan to keep it.
Michelle
92 Formula 350
91 Z28
Old Aug 17, 2001 | 10:38 AM
I just want to verify the oil pressure. I thinkg the sender is fried.
89GTAOz
May 16, 2020 09:31 AM
Reddeath210
Oct 6, 2015 08:20 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
