just my luck
Old May 11, 2005 | 07:51 PM
fearfactory17's Avatar
Car: 1989 Pontiac Firebird
Engine: 2.8L V6
Transmission: auto
just my luck
while putting my valve covers on a bolt slipped out of my hand down my intake manifold, into my head, any suggestions, i dont feel like taking it all back apart again......
Old May 11, 2005 | 07:55 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
You should just be able to pull the intake manifold off and get to it
Old May 11, 2005 | 09:31 PM
Engine: 2.8L V6
Transmission: auto
thank ***, i was just able to get the bolt out with the help of a good magnet and a coathanger, i was real careful and was able to pull it right out
Old May 11, 2005 | 09:35 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Cool, it really sucks to get through with something and then realize you have to go back
Old May 13, 2005 | 05:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Magnetic pickup tool... they cost like $3
Old May 14, 2005 | 10:00 PM
sellmanb's Avatar
Car: '86 Berlinetta
I did something similar to this... I had my distributor hold down clamp bolted onto my intake manifold so I wouldnt lose it, and time came to put the distributor back in, so I took the bolt out, and it fell out of my hand and down the distributor hole after I had everything hooked up to the engine!
Luckily, the cam gear and oil pump driveshaft caught it and I was able to get it with my magnetic retractable light tool... very useful, and very cheap considering it would have taken me atleast 8 hours to get the pan off, plus costs for new oil... so 15 dollars = lots cheaper than 30 in oil and 8 hours of labor (however much an hour I charge myself to work )
Old May 15, 2005 | 12:19 AM
Air_Adam's Avatar
I actually have two pickup tools... they both save my *** ALL THE TIME!! One is a magnetic one... basically a 2-foot long coil with a 2" long magnetic stick at the end. Works great for picking stuff up off the ground and weird places. The other is a 2-foot long coil, but has a 3-prong claw that opens up when you push down the button on the other end. This thing is AMAZING for getting stuff dropped down into the engine, because it can grab pretty damn hard, and it is NOT magnetic... meaning its not bouncing around the block sticking to everything but what you want to pick up.
I suggest getting both. They save alot of sanity, and your neighbors hear fewer 4-letter words.
Old May 15, 2005 | 12:55 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
I have both those things and they are invaluable. They are awesome. I never lost a bolt into the engine yet tho. Hope I never do. I shouldn't even be thinking about this, got my self jinxed now. Next time I have an engine opened up, guess what's going to happen to me.
Old May 16, 2005 | 01:03 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
LOL! half inch!
Elephantismo
Feb 13, 2019 12:51 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
