TDC
Old Aug 17, 2001 | 08:24 PM
red350Z's Avatar
TDC
heres my problem. i know my timing marks on the timing chain are wright but i cant get the rotor phased properly. to get the car to run i had to move all my spark plug wires and i cant get the timing correct
91 Z28 5.7
slp headers
random tech cats
flow master 80 series
crane afpr
xtream energy cam
218-224-485"-503"
accel 8.8
accel coil
acell cap and rotor
b&m mega shifter
Old Aug 17, 2001 | 08:33 PM
ede's Avatar
ede
not sure what you did to get where you're at but i tihnk the best thing is to start over. makes sure the marks on the timing gears are right even if you know they are. bring #1 up to TDC with both valves closed then set the rotor to point at the #1 post of the distributor cap. make sure all the wires are ran to the correct plugs. it should start and run there or with a little moving of the distributor. by any chance do you have it 180* out?
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
92camaro350cci
Oct 14, 2015 09:29 AM
db057
Sep 4, 2015 07:57 AM
