Warning about plastic pressure hose
Old May 12, 2005 | 07:15 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
On my way home today my hose for my oil pressure gauge sprung a leak. If that wasn't bad enough, the oil that sprayed out shorted out some of the wiring causing a small fire under the dash. Luckily I was able to separate the burnt wires and the car would still start so I limped it back to work a block away. Nothing looks permantly damaged so I was lucky.
Moral is, if you have an aftermarket gauge and are still using the plastic hose, CHANGE IT NOW! I knew using it was a bad idea, I had been told over and over not to use it, I knew that it would eventually leak, but I kept planning to do it "next week". I should have used the copper tubing the day I installed the gauge.
Old May 12, 2005 | 07:47 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Warning about plastic pressure hose
I was always told not to use copper tubing for brake systems. Vibration will fatigue the copper and cause cracks leading to leaks.
I don't see why the same wouldn't hold true for any automotive application.
Old May 12, 2005 | 07:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
NHRA and IHRA won't let you on the track if you use the plastic line. It must be copper or a steel braided hose.
Old May 12, 2005 | 07:55 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Brake systems are under way more pressure than oil. Just kinda sucks I kept putting off using the copper tubing. I just want to try and prevent this from happening to anyone else. It could have been much worse.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
Strick1
Sep 4, 2015 07:11 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
