Easy valve stem seal R&R
Old Aug 18, 2001 | 12:17 AM
colincamaro's Avatar
Maybe I'm a little behind the times but I just found out theres a tool set to replace the factory junk valve seals on your car. You pull the valve covers off, and remove the spark plugs. Then put compressed air into the cylinders one at a time. And use a special valve spring compressor. Then do the seals one at a time. just did it and it took 4 hours.. just thought I'd share
89 RS 305 TBI/Hooker catback
Old Aug 18, 2001 | 12:48 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Everyone learns about it eventually. I've used one for years. The only drawback is that you need an air compressor which not everyone has access to.
Old Oct 13, 2007 | 04:26 PM
JeffD's Avatar
Car: 1988 Pontiac GTA
Transmission: 4 spd automatic
Re: Easy valve stem seal R&R
Colincamaro/Stephen 87,
I bought the spring compressor tool and have all the seals to do the job. After starting the job on the #1 cylinder (front/drivers), that one went fairly well; however, looking at all the air pump hardware (brass lines going into the exhaust manifold) it is going to be a nightmare to get compressed air to the remaining cylinders. Did you do anything in particular to get around all the junk to go so fast? Also, any hints as to how to tackle the passenger's side? And finally, did you actually make sure each cylidner was at TDC prior to pumping full of air and proceeding with the replacements? I had a hard time judging TDC doing the work by myself. Any help is greatly appreciated!
Jeff
Old Oct 13, 2007 | 05:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Don't worry about where the piston is, it doesn't matter.
Old Oct 13, 2007 | 05:40 PM
JeffD's Avatar
What PSI would you recommend for a safe "no matter where the piston is located" replacement job? We had it at 90PSI and it was enough to start moving the crank so we backed down to 60PSI.
Thanks,
Jeff
Old Oct 13, 2007 | 05:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Don't worry about the crank moving either.
Old Oct 13, 2007 | 05:57 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
As long as your timing stays still, you're golden. Oh, and as long as that valve doesn't drop into your cylinder. I need to friggen do this, but I alas don't have a compressor. Rope trick time.
Old Oct 14, 2007 | 08:18 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by JeffD
....And finally, did you actually make sure each cylidner was at TDC prior to pumping full of air and proceeding with the replacements? I had a hard time judging TDC doing the work by myself. Any help is greatly appreciated!
Jeff
If you remove both rockers before you air the cylinder, it doesn't matter where the crank is. (ya gotta do both valves anyway)
Use as much air pressure as you can lay your hands on. Let the crank rotate when you air it up, without chopping off any fingers.
Old Oct 14, 2007 | 08:47 PM
Or, you can do it the way us lazy people do...
Put the piston at TDC; stuff about 2' of 5/16" nylon rope in the cyl; do it to it; pull the rope back out.
That way, there's ABSOLUTELY NO POSSIBILITY of ever dropping a valve in.
Magman
Sep 12, 2015 10:43 PM
gixxer92
Sep 1, 2015 04:32 PM
Strick1
Aug 27, 2015 08:57 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
