blower problem
Old Aug 15, 2001 | 05:08 PM
custman87T/A's Avatar
blower problem
When I turn the A/C and blower on I get no blower operation on high. Low, med.low, med.high work but no High. I have an 87T/A with electronic heat controls. I was told there is a difference between that and manual. What do I look for? I tested power to the red wire at the relay and get power. Thanks.
Old Aug 15, 2001 | 05:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Test for power while the blower switch is in high and everything is hooked up normally. I'd bet it won't be there.
ICON Motorsports
Old Aug 15, 2001 | 08:11 PM
so what are you trying to say is that the switch is bad??
Old Aug 15, 2001 | 08:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Usually the connector in the red wire that feeds battery to the relay burns up.
ICON Motorsports
Old Aug 16, 2001 | 06:25 AM
I have checked old posts regarding that and I have power in and out of that connector. Last night after removing the connector from the relay and plugging it back in I got high fan and low fan but no between settings. I will order a relay today and see if that solves the problem.
Old Aug 17, 2001 | 02:30 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Check the blower resistor pack. Its mounted atop the evaperator case (Has like 4 wires or so coming out) unplug it and with a 7mm wrench take it out and check to make sure it isn't broken.
Old Aug 18, 2001 | 05:28 AM
I checked the resistor pack and it isn't bad but I picked up another one from my parts car and no changes. This is driving me nuts I cant seem to find the problem. I guess I will go to the dealer and order a new switch and start replacing from there.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
