smoke from steering wheel?¿?
Old Aug 15, 2001 | 11:27 PM
iroc420's Avatar
I was driving my 86 camaro and smoke was coming from my streeting wheel. well where the steering wheel and colume meet. not alot just a little and for only a few sec. It happened a few timesA few day later my heater core busted. Could that smoke been from the heater core leaking?? any help is needed.
Old Aug 16, 2001 | 12:47 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
The smoke is usually from the turn signal switch assembly or wires for cruise control or wipers grounding out inside the column.
Has nothing to do with the heater core.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Aug 16, 2001 | 09:24 PM
iroc420's Avatar
is it something I should worry about. How hard is it to fix??
Old Aug 16, 2001 | 10:03 PM
reborn's Avatar
Had that happen to me in a non thirdgen car. Mine was the turn indicator shorting out or something. Just open it and find whats burnt looking and replace it. Be a tad carefull, theres a fair few parts in there.
Old Aug 16, 2001 | 11:02 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
<font face="Verdana, Arial" size="2">Originally posted by iroc420:
is it something I should worry about. How hard is it to fix?? </font>
I would worry about it, its a fire hazzard.
Its not bad to replace, but a little complicated.
I belive there is a tech article on how to dis-assemble the column.
If not, Vader has a great exploded view of the column.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Aug 17, 2001 | 04:57 AM
Synergy's Avatar
Actually it CAN be smoke from the engine compartment traveling up the column and exiting right behind the steering wheel. It happened to me today.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car !
Old Aug 17, 2001 | 09:05 AM
ATOMonkey's Avatar
You should be able to smell the difference between burning oil, wires, or coolant.
Old Aug 18, 2001 | 12:21 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Synergy:
Actually it CAN be smoke from the engine compartment traveling up the column and exiting right behind the steering wheel. It happened to me today. </font>
You must be missing the foam "seal" that is supposed to surround the inner jacket and steering tube bearing:
In case you get this far:
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 18, 2001 | 01:26 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
Vader I just love your visual aids when you help solve a problem!
Now here's a guy that takes his own car apart just to show you what he's talking about.
Now that's what I call service!!
Ya gotta love this guy!
SlowAZ28
Aug 31, 2015 07:56 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
