WHEN does the A.I.R. system function?
Old May 13, 2005 | 06:32 PM
rsn932's Avatar
As the subject says, when does the A.I.R. system actually send air into the manifold tubes and to the cat? I know this has been covered before but I just couldn't seem to find it in a search. If I remember correctly, doesn't it send air to the manifolds and the cat at different times? If this is true, I am more concerned with when air is pumped into the cat. If it's not true, then laugh at me and tell me what really happens. Thanks.
Old May 14, 2005 | 02:29 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
When engine is cold "OPEN LOOP," the port solenoid is energized and air pump pressure opens the passage to the exhaust ports.
During normal operation "CLOSED LOOP," the port solenoid is de-energized, the converter solenoid is energized, and air pump pressure opens the passage to the catalytic converter.
When the ECM determines that air divert is necessary, both solenoids are de-energized and air pump output is diverted to the air cleaner through a divert/relief valve. The divert/relief valve limits system pressure.
Air is diverted to the atmosphere under the following conditions:
  • Rich operation.
  • When the ECM recognizes a problem and sets the "Service Engine Soon Light.
  • During deceleration
  • During high rpm operation when air pressure is greater than the setting for the internal relief valve.
Old May 14, 2005 | 10:11 AM
rsn932's Avatar
Thanks a lot. So essentially when the car is in closed loop during normal driving, air is always being sent to the cat except for during high RPMs?
Old May 14, 2005 | 10:02 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
during high rpms as well if the pressure is less the the relief valve setting.
Old May 14, 2005 | 11:42 PM
rsn932's Avatar
thank you
Old May 2, 2007 | 05:32 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: WHEN does the A.I.R. system function?
you guys know how to test if the air divert valve is operating properly?
Old May 3, 2007 | 08:11 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
RaverRacerX
Mar 17, 2026 01:49 AM
wigmobile
Feb 26, 2025 02:56 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
sreZ28
Oct 22, 2015 08:21 AM
