couple few questions....
Old May 14, 2005 | 08:26 PM
cootershooter's Avatar
Car: 70 el camino
Transmission: th350
ok so I've been searchin a little bit and I can't really find an answer to my sitiation...I have an 84 z28 with a 350 and th350 out of a c20...and if I get on her a little bit there's a ton of smoke comin out of the breather cap...and I don't htink it's normal...if I'm goin down the highway it comes in the interior and it's not really that pleasant...and I'm kinda clueless about this...any help would be greatly appreciated...thanks in advance
Old May 14, 2005 | 11:10 PM
sellmanb's Avatar
Car: '86 Berlinetta
that'd be blowby, caused by worn piston rings.
Does it also have blue smoke coming out of the tailpipes of the car?
Frankly if you have that much smoke coming out of your engine's crankcase then you've got a major problem... but if you have a big hole in your exhaust and when you get on it the smoke comes into the cabin that isnt AS big a deal... but still pretty bad.
There's some "ring seal-4-good" stuff that you can try that they sell at autozone. I believe that's the name of the product, but dont quote me... anywho, it's a really thick oil that's like honey, and it makes it harder for the rings to "blow by" since the oil should seal it up a little bit.
I'm assuming that you change the oil frequently? If you havent in a while you may want to switch to a higher mileage oil, that is created to help with the drawbacks of many years of running dyno oil... it's a little too late to put synthetic in now and not chance it.
Old May 14, 2005 | 11:25 PM
Car: 70 el camino
Transmission: th350
ok so there's no holes in the exhaust, and, it doesn't smoke out of the pipes at all...so what would I be looking at for price to fix? the engine is out of a truck, and I was just wondering if I'd be better off tryin to find a 350 out of a camaro or other car, thus having different heads and cam and such, or be better off just to swap those onto this one? thanks for the quick reply
Old May 15, 2005 | 09:45 PM
sellmanb's Avatar
Car: '86 Berlinetta
The fix would be to tear it down to a bare block, and have the machinist hot tank and magnaflux your block, then have it honed or bored out, then you'll need to get new pistons (all 8), new piston rings (this is your faulty part that is causing you to do a rebuild), and if you dont choose your pistons wisely (same weight as the stockers) then you'll need to have your crankshaft balanced.
And since you're doing that anyways, and you'll have pulled the crank you may as well put in new main and rod bearings....
so in short, it would probably be more worth your time and money to get another 350 from a Camaro or Corvette or anything else that is semi performance related....
Unless you want to build a motor exactly as you want it that is.
Old May 15, 2005 | 10:02 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
back the truck up!
are you using any kind of pcv system?is it functioning properly?
heck!a pcv valve is like 3 bucks these days!
is it oil smoke or water vapor?
could be a bad valve guide but i doubt it.you have a problem in the crankcase ventilation area!won't kill you or your motor,bu t it can get annoying!
Eric
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Linson
Oct 1, 2015 09:50 PM
