gas mileage mods that can be done
Old May 16, 2005 | 03:33 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
ignoring the basic tune up which I'm sure we all know about what can be done for mods to improve gas mileage?
a few things I know of at least
inflate tires a little more
remove dead weight from the car
run skinny tires
use synthetic oil and maybe oil of a thinner weight
and of course gearing
what else though? hopefully without reducing power output much?
anything with the cam, heads, intake manifold?
what about using a little larger airdam?
what can you do for a carbed car different or maybe for a efi car to help out?
Old May 16, 2005 | 05:05 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
upgrade ignition system from battery to plugs
dump excess weight
maintain all sensors
fuel injector cleaner with every oil change
etc
Old May 16, 2005 | 06:22 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Fuel injector cleaner doesn't work. Waste of money. Injectors need to be removed and sonic cleaned if dirty.
Not much left besides switching to a more efficient engine like an LSx.
Old May 16, 2005 | 11:44 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
small cam, good matched heads, and EFI will do the most for fuel economy. Full synthetic from bumper to bumper is also a good idea.
If you have a V8, though, its going to get relatively bad fuel economy unless its the <200 HP setup that I previously mentioned. Although an efficient engine can do well with EFI so long as it isnt too crazy. Before I got my 96 taurus, I was considering this mod:
Fugly little thing, but when Im rushing to work and back Im not really concerned with what Im driving.
Old May 16, 2005 | 03:43 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
Take off easy from stop lights. This is where most gas goes.
Old May 16, 2005 | 05:58 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Better flowing intake tract such as the air cleaner and filter as well as a better flowing exhaust system.
Keep the car clean.
Take a dump before you drive.
Eat less.
Fill the cabin with helium balloons.
Ok... I'm getting silly now. Maybe it's the helium??
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
dbrochard
Oct 3, 2015 12:43 PM
TheTraut88
Sep 7, 2015 05:22 PM
TBRays98
Sep 6, 2015 05:05 PM
