LT1 Camshaft, 305 TPI
Old 08-19-2001, 06:28 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I may be putting an LT1 cam in my 305 TPI, along w/ a ported/siameesed base. My car currently runs 9.5 in the 1/8th mile. Anybody wanna guess what gains/losses I might encounter after the swap? I do have chip burning capabilites. Other mods in my sig.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old 08-19-2001, 06:59 PM
Synergy's Avatar
Isn't a stock LT1 camshaft kind of small for your 305 ? As I recall the lift numbers aren't much higher then a stock L98 cam. I'm sure it'll be a little better than a stock 305 cam, but I would say you should gain 10-20 HP from it.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car !
Old 08-19-2001, 07:46 PM
irocbsa's Avatar
I don't know, that LG4 cam is the worst damn thing around. Worse than the peanut cam. I think he should see a bit more than 10-20HP. Aren't you putting the siamesed manifold on there too. I'd think you could get about half a second in the 1/4 from those two mods since the LG4 cam sucks so much.
bsa
Old 08-20-2001, 12:42 AM
Vader's Avatar
GMT,
New87 installed a "B" car LT1 can in his 3053 and cut some time from his ET. He may have details.
Later,
Vader
"Get UP - Drop the bombshell!"
Adobe Acrobat Reader
Old 08-20-2001, 09:27 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
There's no way the cam won't be worth at least the amount they dropped going from the 202/207 cam to the peanut. That was 25hp. What's the specs on the Lt1 cam, it is an improvement over the better TPI cam IIRC? I'm guessing a 30ish hp gain from the cam, plus a bit from the base. I think the roughly half second in the quarter gain like someone else mentioned seems about right.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old 08-20-2001, 09:47 AM
Beefy89's Avatar
I,m running a 96 LT1 cam in my 89 L98.I havent had it to the track yet,but it was definately an improvement.When I rebuilt the engine I also hogged the snot out of the L98 heads,installed 2 valve relief pistons(which bumped the c/r up to 9.75 to 1),1.6 roller tips, ported the base,runners, and plenum,SLP headers,and a Hughes 2500 stall tourque converter.The lift on the L98 cam were .415/.430 and the lift on the LT1 cam with 1.6 rockers is roughly .477/.490,which I would consider to be a decent upgrade for my daily driven GTA. Hope that helps
Shoot Shoot!!!!!
[This message has been edited by Beefy89 (edited August 20, 2001).]
Orr89RocZ
04-25-2016 08:28 AM
gta90
09-15-2015 04:00 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: LT1 Camshaft, 305 TPI
