Idle to High?
Old Aug 13, 2001 | 10:27 PM
RS91's Avatar
Idle to High?
After replacing my fuel injector and ECM I finaly got My 91 TBI 305 Chevy Camaro running. My problem now is that my Idle is to high. What could be causing this and how do I lower it down...
thanks
Old Aug 13, 2001 | 11:07 PM
silver89Rs's Avatar
you could have a vacum leak some where. after i got mine running i had a leak in the thermac vacum line
89 Rs camaro
305 tbi
3in flowmaster muffler
manderal bent pipe
no cat
ELECTRONICS
viper alarm
pioneer 4-way 6x9's
powered by a kenwood 75x2 amp and a aiwa head unit.
Old Aug 14, 2001 | 10:08 AM
manuel's Avatar
I had the similar prob. I almost $hit in my pants when it ran.
I said I "HAD" the prob. I got it fixed by myself. If I can do it,so can you.
Ok.remove the IAC valve.See if there is any crud in the passages,clean it if there is any. Next you will need to check the IAC valve.If has not been replaced,then it is time.
Check all the hoses and vacumme lines form the Throttle Body.If they are loose or cracked.
My problem was the MAP,IAC, and the throttle body gasket. I replaced the them and my car ran like new. The gasket was worn and cracked.Making a vacumme leak.making it rev really high at idle.
When you drive the car may stall,smoke,and even make the throttle body air passages more dirty.
I recommend removing the throttle body and clean it good.really good.goto auto zone and get a gasket form a throttle body kit. then install a new IAC valve.and replace the MAP.
Tell us on how it goes.
Old Aug 14, 2001 | 11:01 AM
RS91's Avatar
thanks guys. I'll take your advice and do it on the weekend. I'll let you know what happens then....
thanks..
Old Aug 20, 2001 | 09:51 AM
RS91's Avatar
Yes!!! It was a vacum leak. the hose going to the air cleaner has a cut on it. I replaced the hose and there it she is no more high idle...
more problems to solve comming up.....
again thanks for the help..
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
86iroczwv
Sep 3, 2015 06:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
