"grrrrrr" sound coming from rear?
Old Aug 19, 2001 | 03:26 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Okay, I have a couple questions. One is in regards to this noise I've been hearing lately. Its a loud "grrrrrrr" sound coming from the rear. I don't know what it is and I can't really describe it any better than that. Is something wrong with my rear end? What should I do about it?
Also, once in a while my brakes squeak really bad and are really sensitive. It usually happens after it rains or after I wash the car. Yesterday (a rainy day) I went to Wendy's to eat, came out maybe 20 mins later and as I was goin through the parking lot, I tapped the brake to slow down for a turn. Well it felt like the brakes locked and the car actually skid. I only hit them VERY lightly. Do I need new brakes?
And finally, when I put the car from park into drive or reverse, the car makes a soft "knocking" noise, hesitates, then jerks a little and goes. Is something wrong with my tranny? Sorry for the long post, but I wanna get these things squared away because I am considering selling the car. Thanks for any help.
1992 Camaro RS
5.0L TBI
Custom white-faced gauges
K&N Airfilter and ready to take on the world!
My 1992 RS
Old Aug 19, 2001 | 03:48 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
A "grrrr" that increases with speed is usually an axle bearing.
A "grrrr" that will get worse while on the gas and a little quieter when off the gas in usually a pinion bearing.
You didn't mention if the brakes were drums in the rear, assuming from the description, they are.
Drums will get touchy in cold weather/wet weather or first couple times in the morning if the drums are out of round. If the shoes are in good shape, you can usually get away with just turning the drums.
As far as your "knock", check the trans mount first.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Aug 19, 2001 | 04:58 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Thank you for your help. How would I change the bearings? Is it a DIY job or should I get a shop to do it? And yes, my brakes are drums. All I have to do is turn them? Thanks again, I appreciate it.
1992 Camaro RS
5.0L TBI
My 1992 RS
Old Aug 19, 2001 | 05:35 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Mettalli, I got the same 3 problems you have. We should meet and compare cars. In fact if the problems are the same we can go to the same mechanic and probably get a two-for-one discount deal. Email me!!!
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Old Aug 19, 2001 | 05:38 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
As far as the brakes, inspect them and make sure they are good and the wheel cylinders are not leaking.
Since you have a bearing noise and a brake grabbing problem, I would take a guess that the axle seal is leaking on the brake shoes, causing the problem. There is a good chance that the axle is wasted also.
If thats the case, you will need to replace the linings, seals, bearings and an axle or 2.
Axle bearings aren't bad, but you need some special tools to do the job. You need to use a slide hammer and a bearing puller to get the old ones out. The new ones just pound back in.
If its a pinion bearing, you should take it to a rear end shop.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited August 19, 2001).]
Old Aug 19, 2001 | 05:42 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Not a bad idea, I'd like to see your car in person. I don't know when I'd be able to meet ya though, I'm working most of the time and if I'm not working, I usually have plans with my girlfriend. Maybe I'll go to this Blue Top I hear about, but I don't know.
1992 Camaro RS
5.0L TBI
My 1992 RS
Old Aug 20, 2001 | 06:47 AM
Axle/Gears: Posi
Yeah come to Blue Top on Friday at about 9 p.m. There are actually 2 cruise spots within a mile of each other so Friday nites are really pretty wild over there. I believe you can meet Denny this Friday also. He's got lot's of cars and parts. Email me for more details and directions. Your problem sounds real simular to mine. BTW what's happening with your pic in the sig.? We want to see your car. I know it's sweet. Maybe I can help with that too.
Old Aug 20, 2001 | 11:22 AM
Car: 1989 IROC-Z
Engine: 383 stroker
hmm.. sig pic shows for me.. I don't know whats wrong
1992 Camaro RS
5.0L TBI
My 1992 RS
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
db057
Aug 22, 2015 08:17 PM
mustangman65_79
Aug 8, 2015 12:07 PM
gwade12
Aug 8, 2015 08:17 AM
