Frozen Door Handles, What can I do???
Old Aug 20, 2001 | 09:06 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Last winter any time that it got really cold and my door handles want freeze shut along with my door. It didn't have to snow I guess just condensation that want get in the cracks would freeze. Several times I had to get a blow dryer to unfreeze it.
I am going to college in a week and it's in the mountains so it snows from like September to April and will be colder than where I live now.
What can I do to avoid using a blow dryer every day?
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 20, 2001 | 09:32 AM
iroc5speed's Avatar
well, when my doors froze shut I just opened the hatch and crawled through. You just unlock it and pull up. Easier than trying to blowdry the doors.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
Old Aug 20, 2001 | 02:03 PM
AlexJH's Avatar
Engine: 5.7L V8
I did what iroc5speed did too.
Maybe a remote starter would work with your heater turned all the way up the night before... not sure how long that would take though.
Old Aug 20, 2001 | 02:26 PM
87tpi420's Avatar
could you vaseline the door seals? not load it up, just a thin coating. it may help keep water from going inbetween the seals and freezing the door shut. also might want to put some lithium white grease in the dorr handle assembly. whatever you can do to keep water out. you could hang a trash bag over the window from the top with a couple small magnets? that would keep the snow out too (but a pain in the butt). i would give the vaseline a try, dont know if it will work.....but sounded good when when i thought of it just now.
what i do know is....you can actually pull the door seals off the car if you force the door open. they will stick together and then your really up sh|+s creek.
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Aug 20, 2001 | 02:49 PM
rudys119's Avatar
lol, that is too funny....
This is one of the few times i am actually happy to live in Florida.
87 GTA 350 TPI
Mods: K&N Air Filter, New rocker arms, Stage III chip.
Next Mods in line: Exhaust, headers
http://www.geocities.com/rudys120/transam.html
Kills:
Nissa 300zx (dont think it was turbo)
87 Mustang 5.0,
89 Mustang 5.0 (modded)
?? Iroc
00-01? Jaguar driven buy 85 yr old guy
Too many ricers to count......
Old Aug 20, 2001 | 03:50 PM
[-sLaYeR-]'s Avatar
Winters in BC Can get pretty cold, so that's common for me. I just splash it with a bit of water, and it opens fine. However, if it cold enough, once your parked and get back in, you'll have to do it again. Works everytime though. Once I do it in the morning, it's usually fine the rest of the day. Dunno about where your going though.
Old Aug 20, 2001 | 03:55 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The Jeep guys were the ones using the vaseline on the door sills.. they'd go off roading, and then couldn't get back into their jeep! So it will work; but as for the handles themselves freezing, sounds like you need to pop off the door panel, and lube everything up. Don't use WD-40 or similar inside the locks, WD-40 will wash any lube away, and your keys might not work. Use the specialized "graphite lube", it's used for all locks, so if you can't find it at an auto store, try a hardware store.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Aug 20, 2001 | 04:17 PM
firbird's Avatar
!!! that happened to me and i live in florida
Veaceonee
Sep 29, 2016 08:15 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Buggy Disaster
Sep 17, 2015 05:12 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
