Removing my valve cover
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
Removing my valve cover - HELP
I just did my header install and I was going to remove my valve cover to check things out and here is what I can not figure out. I have an 86 with the four small nuts on the outside of the cover and it uses the spreader under it. I removed all four nuts so there was only the post. I began to try to remove the cover and it won't budge. I was bending the edges trying to get it off. Am I missign something here, loosen four nuts and pull right?
NBrehm
Aug 25, 2015 11:49 PM
