cold start valve/ninth injector
Old May 18, 2005 | 12:55 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Anyone know what the resistance should be? Its reading 4.5 ohms now and thought it might be leaky causing my surging idle.
Old May 18, 2005 | 01:26 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Alldata doesn't show specs for the cold start valve, I assume it's the same as the others 15.8 to 16.6 ohms at 68°F.
Old May 18, 2005 | 01:52 PM
kcallais's Avatar
Car: 1985 Z28
Dang, thanks anyway. I was hoping someone with a CSV could take readings off of theirs.
Old May 18, 2005 | 03:43 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you want to check for leaky injectors, pull the rail off and place a pan under it and then jumper the fuell pump relay and see if any of the injectors leak.
Before doing that, hook up a fuel pressure gauge and see how long it holds pressure after it presurizes for 2 seconds.
If it drops down quickly, you can have a leaky injector, leaking regulator, or a fuel pump with a bad check ball.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
