Recall Question
Old Aug 21, 2001 | 08:52 AM
84camaro's Avatar
Recall Question
Hi - I went on autozone.com and typed in my VIN number, and glanced through the recall notices. Specifically, I have the problem with the seat-belt where it doesn't retract. The letter says to bring an identification card into the dealer to get the work performed. Unfortunately, the car has been sold/given about 4 or 5 times since the original owner, and I seriously doubt Chevy even knows I exist.
Should I take it into a dealership anyway? Will I have to reference the specific recall notice, or can I just tell them the problem and they'll fix it?
Old Aug 21, 2001 | 10:03 AM
82camaro's Avatar
Car: 82 camaro SC
Call a dealer, give them the vin number and the info on the recall. They can punch it in and see if the recall has been fixed on your car. If it hasn't been fixed yet per the VIN number, they should fix it.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
GTAman
Mar 15, 2019 11:40 AM
Eric2ndGen
Aug 31, 2015 11:30 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
