Long block or short block?
Old Aug 21, 2001 | 02:11 PM
uno's Avatar
uno
ok...I know the basics, but i would like some real info on the difference between a long block and a short block...and is there any problem puttin a 2 bolt main motor in an 89 camaro? thanx in advance
1989 307 RS, soon to be 350.
1995 Red T-Top Camaro, 3.73 gear, F.I.P.K. K&N,Flomaster Cat-Back, Gutted Cat...Killer Stereo (Cerwin Vega and Sony Xplode)
Old Aug 21, 2001 | 02:30 PM
ATOMonkey's Avatar
Long Block is the block, crank, pistons, cam, heads, valves, springs.
Short Block is the block, crank, pistons, cam.
The long and short block are almost always pre-assembled.
Yes a 2 Bolt Main will fit just fine.
The only problem you might run into is the difference between the one piece '87 and later cranks and the two piece pre '87 cranks and what flywheel/flexplate you have to run.
anesthes
Mar 10, 2016 10:35 PM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
BBSDesigns
Aug 11, 2015 07:39 PM
