Oil pressure always at 60psi?
Old Aug 21, 2001 | 12:54 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Recently my oil pressure has stayed at 60psi, even at idle after the car is warm. I always thought that when the sender went bad it either stayed at 0 or it pegged the needle. Any opinions before I cough up $20 for another sender? (Hopefully the new one will last more than 5k miles if the sender is at fault)
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Aug 21, 2001 | 12:59 PM
z28dan's Avatar
When you turn your key to the acc position does the oil gage go to 0 or 60? If it goes to 60 then you have a open circuit. Also make sure you sending unit is for a gage type, not a light.
1988 L98
Vette Heads/no EGR
SLP Headers/Y-Pipe
ARAP bin
Old Aug 21, 2001 | 02:32 PM
Jim85IROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by z28dan:
</font>
I'll check it after work and get back to you. It's a sender for the gauge type. It's worked fine for the last couple years.
The IROC Homepage
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
