PCV valve leaking oil on valve cover
Old May 20, 2005 | 11:26 AM
Abubaca's Avatar
Simple problem. The passenger side pcv valve is leaking a little oil on the valve cover. Not much at all, except that I show the car, and I'm always having to clean it up. I was thinking about smearing a little RTV around outside of the valve to make it fit more snug.
Any suggestions?
Old May 20, 2005 | 11:37 AM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Replace the grommet it is probably old and dry. They are really cheap at any auto parts store.
Old May 20, 2005 | 01:11 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Replace the grommet...
Old May 20, 2005 | 10:05 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Give me the car and start walking everywhere?
As mentioned, I'd look to the grommet as the culprit. Probably inspect or swap out the pcv as well to see if you got a damaged one.
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
1985chevydude
Aug 20, 2015 12:29 AM
86White_T/A305
Aug 17, 2015 12:16 AM
