Need help with cam selection>>
Old Aug 21, 2001 | 07:38 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I need select a cam ASAP and I wanted to get all the imput that you guys might have
it's going to be
383 ci
6" rods
8.5-1 compression
2.02 1.60 trick flows
12-15 PSI supercharged "ATI"
SLP runners & headers all that good stuff
umm 52mm thorttle body ((but that cam be changed))
I think that's it
please any input you might have need to choose SOON I was thinking either COMP's or CRANE
THANKS
Hecubus
Check out my site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~ 175-200hp shot/ 255lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt./Trans-Go shift kit
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Aug 21, 2001 | 09:30 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
oh also I'm in CA so I need to make shure that it will be able to pass smog NP as well
I was told that with a supercharger12-15 PSI that a 114-116 seperation would be best.. so not to dump too much fuel out exhaust.
also I'm thinking a 2300-2400 stall converter will work best for this combo for daily driving what do you think?
Any one have any ideas for me?
thanks!
Hecubus
Old Aug 21, 2001 | 10:03 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
comp cams 276HR-14 would be a decent cam for what your planning assuming your going roller for an originally equipped roller engine. duration is 276 and 290 advertised, 220 and 230 at .050, with .510 lift on both. lobe seperation is 114 as recomended. with a 2400 stall speed converter, you'd be set up nicely. just need some good tires then. just my thought on a cam, but more opinions to come.
Old Aug 22, 2001 | 02:27 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
NE1 else??
Hecubus
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
customblackbird
Oct 1, 2015 04:30 PM
masonta
Sep 1, 2015 06:40 PM
