sparratic oil pressure reading.
Old May 21, 2005 | 12:18 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ok when i first start my car is cold still and driving around its a good 55ish psi . after its warmed up it still stays around 35psi. but i noticed the other day when i floored it a few times that the psi dropped to 0 a few times then after i let off it slowly crawled back up to where its supposed to be. is this a glitch with the stock gauge or should i be cautious of something going on?
Old May 21, 2005 | 03:26 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
prolly the stock sender unit going out
but make sure first and get a real mechanical gauge in there just to double check.
usually the sender is near the oil filter from my experience on the thirdgen though might be a little different
Old May 21, 2005 | 12:52 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i replaced the sender like 8 months ago when i changed my spark plugs for the first time and i broke the original. it is an autozone sending unit so its prolly broke lol but ill get it checked.
Old May 21, 2005 | 01:05 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
My wife's s10 blazer used to do this. Meant is was 2 quarts low on oil. I agree with rx7speed about checking this with a mechanical gauge. If the oil level is ok and it does it with a mechanical gauge, the pickup might have come off the pump.
Old May 21, 2005 | 01:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
is that bad?
Old May 21, 2005 | 01:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes, sucking air instead of pumping oil through the engine is bad. If you'd like I can send pictures of what was left of my cam and lifters after the screen broke off the pickup tube on my car.
Old May 21, 2005 | 02:22 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Ahhh, don't you just love showing symptoms of a spun bearing?
Old May 22, 2005 | 07:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
no, i was a quart low lol
Old May 22, 2005 | 08:06 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
A quart low shouldn't cause a problem.
Could be all the laughig gas you've run through it
BTW, the rears apart awaiting new stuff...should have picked up that tranny while I was there, my nephew needs a core fotr a rebuild.
Oh well...
Old May 22, 2005 | 08:41 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ya its long gone now. good luck with the axle.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
