My 305 TPI runs like crap! :(
Old May 22, 2005 | 09:22 AM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
Hello all, I have a 1988 Pontiac Trans Am GTA with a 305 TPI, all original with no modifications at all... Automatic transmission, 3.27 rear, all options except leather and the 350 TPI.
The problem is, when I give my car 1/2 to 3/4 of of the throttle, it shakes, like it doesn't have all the power... When I put the pedal to the floor, it shakes too, and become good after 1-3 seconds of flooring it... Sometimes when I keep it stomped for like 10 sec, it do it for 1-3 sec, became normal, beging to shake a again, normal.......
Old May 22, 2005 | 03:57 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I need help... Please!
Old May 22, 2005 | 07:20 PM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
commence par les base......ton filtre a gaz, sa fait tu ben longtemps qui est la.......filage bougie etc.......si y manque a laccélération cé soit un mauvait feu ou un manque de gas.....trop paresseux pour écrire en anglais
Seb
Old May 22, 2005 | 08:21 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
SebasIroc: I have changed the spark plugs and the spark plugs wire less than a year ago... Replaced my old ones with ACDelco... I also replaced the air filter also... But I never replaced the fuel filters. Maybe it's my problem?
Any other have ideas?
Old May 22, 2005 | 10:20 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Fuel filter is too easy and cheap not to do. Do it, worth a shot.
Old May 23, 2005 | 08:32 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Should I stick with an ACDelco fuel filter or get one at NAPA or another store like this?
Old May 23, 2005 | 10:25 AM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
ac delco is good but maybe more pricey than other.....I think its 5$ more than other so i would take Ac Delco. I dont know if you will change it by yourself......well if you do it about 20$ if a garage do it about 40-50$.
Bonne chan jespere les fiting sont pas trop rouillé sa ma souvent fait chier
Seb
Old May 23, 2005 | 06:29 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I took the GTA out today again... The problem is still there but less than the other time.
When I'm at a stop light, sometimes it do a little shake here and there, is it a miss? When I remove the foot from the brake and push the gas pedal, it shakes while accelerating. When I put it to the floor, sometimes it go like normal, sometimes it shakes a little and accelerate not as fast, became normal again, slow, fast, slow.......
What do you guys think it could be beside a bad fuel filter?
Nixon1's Avatar
Fuel filters are dirt cheap and so easy to change it's not even funny. I've done one on my 94 Probe, on my dad's 94 Cavalier, and on my 91 Mustang...the Probe took the longest, at 40 mins cause I had to remove all the intake and some vacuum lines, etc. The Mustang, which is along the frame rail by the tank which Im sure is where the Camaro one is located....was 5 mins or less off and on. No kidding.
Old May 23, 2005 | 08:27 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
did you check to see that your spark plug boots are indeed on the spark plugs and posts?
Old May 24, 2005 | 08:01 AM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
I had the same issue: shaking when flooring it. It was the spark arcing onto the headers. Make sure that you didnt burn through any of your new wires. Check them in the dark!
Old May 24, 2005 | 01:05 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
i had same problem, my wires burned through and it was arcing on the headers. Check them all out REALLY carefully. You might also have bad spark plugs (i think someone said that already)
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
