Bent Valves?
Old May 22, 2005 | 01:11 PM
Marlboro Man's Avatar
Car: 1984 Trans Am
Transmission: 5-speed
Bent Valves?
What is the best way to tell if you have bent valves without pullin the heads off, see heres the deal i got the intake off and we have done compression checks and 4 come out as 85 psi and the other 2 are a lil over 100, its a 2.8 v6 so far we have tapped the tops of the springs and all of them flex but 2 of them dont move please guys i need some answers
thanks
Old May 22, 2005 | 01:21 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Put air in each cylinder. If they are bent they will not close and seal. Listen to the intake manifold and tailpipe. Air here will mean a bent valve in the cyl getting air.
Old May 22, 2005 | 01:48 PM
Car: 1984 Trans Am
Will this work even if the intake is off?
Old May 22, 2005 | 01:54 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Yes. It will work with intake off. I forgot to mention in the last post, when working on a certain clyinder, loosen both rocker nuts and remove rocker arms. This will ensure both valves in that cylinder are closed.
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
yeah itll still work but you have to make sure both valves are closed on the cylinder your checkin
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dbrochard
Sep 7, 2015 09:41 AM
