New weird idle problem
Old May 22, 2005 | 04:06 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I've had off and on idle problems for a while. I just cleaned my MAF and it helped a bit. I replaced my battery and alternator recently and that helped a bit as well. When I first start my car sometimes it will stall right after cranking it over if I don't hit the gas. Once I do the RPMs shoot up and stay up like they should. Every once in a while it'll stall, but after running for a few minutes there will be no problems. What should I test?
Old May 23, 2005 | 07:06 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
firebirdjosh,
Idle problems on TPI motors are not uncommon.
I would check the fuel filter and the IAC (Idle Air Control) sensor first. Make sure both are clean.
If both of these are fine and it still occurs, then you may have a problem with TPS (throttle position sensor), EGR, or the fuel pump.
Also, see if the Check Engine Light comes on when this problem occurs.
Hope this helps.
Best of luck!
Old May 23, 2005 | 08:07 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Chased this on mine for months. Finally figured out, I think, it was not getting a good rpm signal from the distributor. Took it out and the pickup coil looked terrilble, connections green, module was nasty looking too. Old age, heat, moisture I guess. Reworked the whole deal and problem solved. Maybe not on your car but wouldn't hurt to pull the cap and see how things look in there.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
CORV3TT3
Aug 23, 2015 11:26 AM
