doing the heater core this weekend. any tips or pointer
Old Aug 22, 2001 | 12:06 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
any ideas??
Old Aug 22, 2001 | 12:09 PM
z28dan's Avatar
BEER! And lots of it!
Old Aug 22, 2001 | 01:09 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
thanx for that one! lol
i just went to get one and they were like 50 bucks! i though there were like 20?
86 Z28:
L98 350
aluminum heads
T-5
235/60R15 BFgoodriches
dual 3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt Sony xplod amp
Sony xplod deck
K&N air filter
http://www.geocities.com/xmikex.rm/mike.html
Old Aug 22, 2001 | 01:11 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It seems most years of Camaro's you have to take out the dash, but on mine all I had to do was take out a black panel under the dash, only took about 30 mins.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 22, 2001 | 01:31 PM
ATOMonkey's Avatar
It's real messy I suggest that you put down quite a few towels in the car or it's going to smell like coolant for a long time. I also recomend lots of beer along with someone to bull$hit with.
Old Aug 22, 2001 | 01:35 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
i bypassed the heater core already when it leaked. so do i still have to drain the coolant?
Old Aug 22, 2001 | 02:04 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
You should not have to drain the coolant since you've already bypassed the core.
From what I see in repair manuals you can get to the core from the interior. Taking off the dash panel might allow some extra light on the scene.
I would have to strongly agree with placing towels on the floor board!!
Even thought it leaked, it may still have a good amount of water in it.
Also remember the ECM is over there as well. You may have to remove the ECM to get better access to the core, but maybe not. Either way try to cover it with plastic or something just incase it gets wet.
This is one of those gotta think ahead type of repairs.
You might want to check into getting the heater core repaired if it's $50 for a new one. Call a radiator shop and ask how much it would be to have a heater core brass welded.
Check around for some more prices, the more money you save on the core, the more money you can spend on that beer you're gonna need.
New Heater Core $50.00
30 pack of Beer $13.99 (bud, coors, etc)
Boom Box Radio $35.00 ? guessing
All the fun you had replacing that heater core while jammin to some tunes and popping a few tops.........PRICELESS!!!!
Note: Prices may vary in your area.
[This message has been edited by sunbitz (edited August 22, 2001).]
Old Aug 22, 2001 | 02:13 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
I'd say blow the heater core out with some compressed air so you don't spill coolant all over the interior. this would help even more if there was coolant in the core. however, if it had leaked into the heater box and has a bunch of coolant in there somwhere (probably usually the case in heater core failures, but probably not for you since it's probably evaporated by now) you still want to take the proper precautions...
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old Aug 22, 2001 | 02:26 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
yea it has been a long time like a month and a half so it should have evoporated. but i will take the in to account.
Thanks guys
86 Z28:
L98 350
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
Old Aug 22, 2001 | 03:46 PM
ATOMonkey's Avatar
I've got a question. If he blows the coolant out of the core where's it going to go? Isn't it going to get all over the engine. Maybe if he had a catch can over the outlet or something. I guess I answered my own question.
Old Aug 22, 2001 | 03:48 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
im just gonna go with clemsparks that it all eveorpated. im not even gonna worry about it. it had to evporate.
Old Aug 23, 2001 | 08:25 AM
ATOMonkey's Avatar
Since coolant has a very high boiling point it doesn't evaporate that well. Couple that with the fact that it's pretty hard for vapor to get out of those two little copper pipes, and I say that there is still enough coolant in there to **** you off when it spills in the car.
Old Aug 23, 2001 | 08:30 AM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
Flush it with clean water first. Then blow it out with air. That way, any water still in the core will be clean and won't stain the carpet or smell bad or feel slimy or...
'87 IROC 5.7l TPI - original owner!
Old Aug 23, 2001 | 09:56 AM
gravitar's Avatar
Having done mine a few years ago, I was pleased to find out that the job LOOKS a lot harder than it really is. First of all, you don't have to disassemble the dash at all. Don't even bother taking the dash pad off, you won't get much light from the top anyway. I don't remember having to pull the ECM, either.
What I do recommend is pulling out the pass. seat so you can lie down in the car. You can't really reach it from outside the car, and you sure can't do it sitting in the seat!
Old Aug 23, 2001 | 10:30 AM
Car: 99 Formula
Axle/Gears: 342
You don't have to touch the ECM, it's under the driver side dash while at least on an 86 anyways the heater core is under the passenger side dash.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
Old Aug 23, 2001 | 10:58 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I did the whole swap from the passenger side from the bottom. Didn't even touch the dash pad or any of that crap. Swapped that sucker out in like an hour.
BTW the ECM is on the passenger side, at least on my old 86 and 87. Not that it matters, takes only a sec to remove it.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Aug 23, 2001 | 11:09 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
rey did you have remove the seat. also i go to napa online and it says a heater core is like 20 bucks on the website site. i go to the store in person and the guy is like 50$. what is the right price for a heater core? or what did you guys pay at least>
86 Z28:
L98 350
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
Old Aug 23, 2001 | 02:29 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
I got the heater core at Discount Auto Parts for like $20 or $25 I believe, under $30 anyway.
I left the passenger seat in place but just about broke my back trying to get to where I could reach/see everything. Probably easier to just take it out I guess.
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Old Aug 23, 2001 | 03:52 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
its aight ill leave the seat in i really don't want to bother taking it out. ill just gonna try and remove the panel on the passanger side with taking out the dash or anything else. hopefully it will turn out easy
no green
Jan 9, 2016 09:22 PM
bjpotter
Oct 2, 2015 09:12 AM
