Stalling problem
Old Aug 23, 2001 | 06:27 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Stalling problem
I'm trying to figure out why my engine 89 (LO3) stalls. It only does it when the car is not moving, it does not matter if it is hot or cold, in or out of gear. When it's just idling the rpm goes up to 2000 or so and then dies.. once and a while It'll not stay running if I try to start it again. It fires revs up to 2000 and shuts off, right after firing.. But If I step on the gas a bit before it quits, it stays running. I'm busy going through the helm manual, the only thing I can think of looking at would be the IAC, or EGR... but since it does this in open & closed loop.. I'm not sure what to do.. The ECM leaves me with not codes other than the normal 12.. Thoughts on this anyone.. . . .
89 RS Camaro, LO3 305 TBI
Cooling Fan Overide Switch
L69 Duel Snorkel Intake
Dynomax Ultra Flo SS Cat Back
[This message has been edited by FastElectrics (edited August 23, 2001).]
Old Aug 23, 2001 | 10:20 PM
BlueRoc's Avatar
I hope someone has an idea, I just got
home and my Iroc is doing the same thing
90/305/T5
Old Aug 23, 2001 | 10:23 PM
manuel's Avatar
Vacuume leak.I replaced the Throttle Body Gasket,IAC,TPS,MAP. It turned out to be the gasket, and black "crud" in the IAC passages. Also Check the connection to the Engine Coolant temp. sensor,loose or bad connection may cause stalling. All in about an hour of work with all the new parts next to you.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
