Swaybar disconnected!
Old May 23, 2005 | 10:45 PM
huntingwood's Avatar
Car: 1989 Trans Am
Engine: l98
Transmission: 700 R4
Axle/Gears: 10 bolt with 3.23s
I was replacing my transmission this weekend and while I had the car jacked up, I noticed that the rear sway bar is completely disconnected on one side. The bushings and the nut that hold it on are missing. I have been noticing a clunking type of noise while making sharp turns at low speed - like a 90 degree turn into a parking lot. Do you think the rear sway bar being disconnected could have been causing this?
Any help is greatly appreciated. Thanks
Old May 23, 2005 | 10:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Quite possibly.
Old May 24, 2005 | 10:10 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Yes, it is likely that the sound was caused by this.
When I bought my car, the sway bars were connected but the rubber bushings were totally eaten away so the sway bar links were just rattling there. ANd the car was handling like a duck in corners. Scary. Put new links on for a few bucks and now she drives like a champ!
Old May 24, 2005 | 11:01 AM
92F-bird_5spd's Avatar
Car: 1992 Firebird
Engine: 305 TBI
Transmission: T-5 w/ Hurst Shifter
yeah, my car made some loud clunking/popping noises when my end links broke. just get some new ones on there, and everything should be fine.
xodus2002
Jul 17, 2020 09:08 AM
gta892000
Aug 11, 2019 11:16 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
