wierd problems/noises with engine
Old Aug 24, 2001 | 12:52 PM
erik_jacobs's Avatar
Just in the past week my car developed a miss. The last couple of days I've been trying to find the problem but can't seem to be able to figure it out. The spark plug wires and spark plugs were looked and and they seem fine. The spark plugs have a light tannish color to them. I looked under the hood at night to see if there was any arcing off the spark plug wires and didn't see anything. There is also a ticking sound that goes along with the miss on the left side of the engine. I looked at the rocker arms on that side to see if any were loose and they were all tight. Then just yesterday that when I rev the engine hard it wants to spit a little bit of gas out the carb everytime it misses. One idea I had was maybe the cat was almost clogged because just recently I noticed that the small exhaust leak I had in front of the cat got louder and the exhuast is just a little bit more muffled. Would this cause enough back- pressure to cause these probs?? Any ideas would great help.
Old Aug 24, 2001 | 02:32 PM
Anybody????
86 Z28
355 w/
New Scat Crank
Balanced
ATI SFI Approved Balancer
'72 75cc Heads w/polished
Combustion Chambers
Blended Bowls,
Undercut Valves &
Port Matched
to Weiand Action+
Factory Q-Jet w/Carb Shop
Stage II Mods
Hypertech Coil w/Holley
Annihilator Dist. Module
Jet Stage II Chip
Energy Suspension
Polyurethane Bushings
Still Not Done With Her!!
Old Aug 24, 2001 | 02:48 PM
ATOMonkey's Avatar
If it spits gas out the carb, that's due to a reversion from the miss. A high pressure pulse travels back up from the cylinder out the engine. I'd adjust all of the lifters while the engine was running. How many miles on ign system? You might want to look into new wires, plugs, cap and rotor. There are only two things that could be going wrong. 1. It's not getting spark 2. It's not getting good compression. If you say it's ticking and all the rockers are tight, then one of the lifters is probably going flat and needs to be replaced. That's my 5000 mile away diagnostic. Hope it helps.
Old Aug 24, 2001 | 03:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Blown head gasket between cyls 5 & 7.... do a compression test.
ICON Motorsports
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
