New engine startup
Old May 24, 2005 | 07:33 PM
littlekings's Avatar
Car: Dirt Street Stock oval track 2bbl
Engine: 350 w/dart iron heads and 383 w/world products sportsman II heads
Transmission: saginaw
New engine startup
How much, if any metal shaving should I see out of the filter after initial startup? The oil in the pan was clear but I poured out the filter and it was streaked with gray. Normal? Bad? Very Bad?
Old May 25, 2005 | 12:45 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
Your very first drain will yield some metal this is normal. Just make sure that there are no shavings or larger pieces, the normal metal will be fine and make the oil look metallic.. This should be totally gone by the third oil change.
Old May 25, 2005 | 11:25 PM
Thanks, yes the oil in the filter looked kind of like silver metallic paint but no chunks or splinter sized pieces. I rubbed some in my palm and couldn't really feel the grit so it must have been very fine.
I am running a dirt street stock car and all this is new to me. This board has been very helpful. Dare I say my car is a Monte Carlo? I've been to other boards and you guys all seem to know the small block chevy better than some of the other boards out there.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
