Why do my plugs keep backing out from my Edelbrock heads???
Car: 2002 SOM z28
I got the spark plugs that were suggested by Edelbrock for the Performer heads and they keep backing out after a while. Especially if I rev up to about 5500+rpms... which happens every damn time I race! I get about 1 or 2 that seem to back out so they rattle around in the hole...not necessarily in any particular cylinder either. I tighten them pretty tightly and they eventually back out... what gives?!? I'm about ready to use some red loc-tite!
Lately I've been getting rather fed up with my Edelbrock stuff...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
My first instinct was to say the different metals expand at a different rate but it seems that it would take it a while to do this. Maybe a month or so of heating up and cooling down.
Have you checked to see if the threads are alright and not stripped a little? If everything looks alright and it still does this try some loc-tite like you said. couldn't hurt.
you should definetly put some anti-sieze on the threads, I'm sure those are aluminum heads.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
'86 IROC 5-speed
305 LG4
'95 3.23 rearend
Guest
Posts: n/a
Edelbrock sucks.
With that said...
Thats probably the problem right there. What kinda plugs are they telling you to use?
With that said...
<font face="Verdana, Arial" size="2">Originally posted by Biochem:
</font>
</font>
[BLately I've been getting rather fed up with my Edelbrock stuff...
[/B]</font>
[/B]</font>
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Car: 2002 SOM z28
Yes they are aluminum heads... I was only joking about the loc-tite... and Jester I'm not pulling them and going with another brand
With that said, I'll have to look tonight on a plug to get the exact name, but it is a RC Champion plug I thing... Like RY 134 or something with 2 metal washers on it. I have them gapped at 0.40".
It mainly happens after I do a high RPM run on the motor...
Guest
Posts: n/a
R what? Champion??? Yuck. At least it seems they are gasketed.
Try a different brand, and see if you can measure the thread length while you are in there so maybe I can tell you if the common vette plugs will work or not. I cant think of any good reason plugs would back out, doesnt make much sense.
Car: 2002 SOM z28
The only things I can come up with are the static compression is very high and/or someone made a suggestion that the two metals expand/contract at different rates... I can only imagine what will happen when I do a 125 shot for the first time! I foresee all 8 plugs shooting out of the block by the end of the 1/4
Guest
Posts: n/a
High compression? Materials?
I have vette aluminum heads on a car running 10.3:1 that cranks 195psi when I checked it two weeks ago, and it doesnt back out the plugs. Something else is going on.
Just curious, are the spark plug holes heli-coiled?
Car: 2002 SOM z28
I kind of counted "materials" out because it happens after a run usually. The holes are the stock holes that came on the heads from the box to my engine.
86IROC112
Aug 17, 2015 02:00 PM
