thinking about building this engine??
Old Aug 24, 2001 | 12:50 PM
92zeddar's Avatar
327 bored over 30 ZZ3 cam with trick flow heads and Eldebrock Runners and intake.. this is just a thought if anyone wants to add ideas please do....
92 z-28 G92 black with white racing stripes.
Dynomax cat back
Hypertech chip
5 speed
Old Aug 24, 2001 | 09:40 PM
Guest
Guest
Posts: n/a
Why a 327, it laying around?
I'd pick a different cam, and the 327 (RPM motor) and the TPI (anti RPM intake) wont get along together so well although it will work.
Old Aug 24, 2001 | 10:10 PM
rezinn's Avatar
I think I heard of someone doing well with a 327 and a miniram intake, if thats in your budget.
Old Aug 25, 2001 | 12:23 PM
92zeddar's Avatar
I picked 327 because everyone has a 350 and I want something different...
Dynomax cat back
Hypertech chip
5 speed
Old Aug 25, 2001 | 12:49 PM
Enkil's Avatar
There's a reason that most people prefer 350's..
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Aug 25, 2001 | 08:39 PM
camaro6spd's Avatar
yeah so he could get much better power out of that then the 305, but i would recommend doing this....
1) getting an aftermarket TPI intake baseplate and porting it to the max siameasing the runner.
2) get SLP semi-sieameased runner and fully port those
3) Port the plenum, runners and baseplate and head to match to the gasket. that should give you some more Rs. Then try to get a cam and head combo that make there power at a little lower RPM, you should have a good performer then.
Old Aug 25, 2001 | 11:17 PM
evil t/a's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 92zeddar:
</font>
Then get a 350 or a 400 and tell everyone that its a 327
Old Aug 26, 2001 | 07:26 AM
92zeddar's Avatar
So what alot of you guys are telling me is to stay away from a 327?? why is that?
Dynomax cat back
Hypertech chip
5 speed
Old Aug 26, 2001 | 08:08 AM
JETHROIROC's Avatar
Personally, I would build a 383 if you're wanting something different from the 350. Or look into that new 427 small block . By using that cam and a TPI setup you will ruin the high-revving performance 327s are so fondly remembered for. If you're going to run a 327, do it right, and run a carb or miniram. IMO, that cam won't be quite enough for it either.
I think the 327 is a cool idea but don't rape it with a TPI setup. Just my $0.02.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Aug 26, 2001 | 11:50 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Some guy I know has a 327 in his z28 and that thing is the fastest third gen I've ever seen but he still prefers 350s. 327s need to rev higher to make the same power as 350s so he has this overly-huge cam in it which makes it barely streetable.
Old Aug 26, 2001 | 04:59 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Why stay away from a 327? Well are you looking to make some power or not? There's a phrase that dates back before my time, probably even before my dads time that he taught me, "There ain't no replacement for displacement!" In other words, Money+Displacement=Power, or this formula can be shortened to money=power since more displacement will generally cost more (although I'm not sure if that holds true trying to build a 327)
If you really want to be different, you could de-stroke a 400...Some say this makes for faster and higher revving motors which is great for horsepower, but probably not as good for the low end torque. Another option would be to grab the buick 3.8 Turbo motor It's all up to what you want to do, and your budget.
Good luck
Corry
Old Aug 26, 2001 | 08:19 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Someday I want to build a twin-turbo 327. I think it would work well since a 327 will rev. Hell why not make it a roller 327? Dude you could chirp the tires into overdrive!
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
midge54
Jan 29, 2017 07:00 PM
italiano67
Dec 11, 2016 09:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
