Valvetrain question need an answer to
Old Aug 26, 2001 | 10:01 PM
iroc22's Avatar
I'm replacing my valve seals in my 305 and I was wondering if I can go with umbrella valve seals instead of the stock GM o-rings. I'm going with a bigger spring also so there won't be any clearance problems with umbrella valve seals right?
Old Aug 26, 2001 | 10:59 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Yes, you can use umbrella seals.
As far as bigger springs, keep in mind they make big springs that require machining to fit the heads. Make sure whatever springs you get will fit the stock pocket in the heads.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Aug 26, 2001 | 11:13 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
Also consider the lift of your cam. At full lift you should have at least .060 between the retainer and seal.
Old Aug 27, 2001 | 04:08 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
It may also be a good idea to put a fresh set of o-ring seals on with the umbrella seals, at least on the intakes.
I hate the blue puffy's
TEEZER TA
Aug 30, 2015 06:35 PM
Bryan F
Aug 18, 2015 02:28 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
