need some help immediately
Old Aug 25, 2001 | 10:04 PM
senjorb0b's Avatar
Alright i have an 87 305 carb camaro and im having a problem. we rebuilt the motor and its been running great until the last few days. when you first start it up cold it wont idle right away, and will stall if u put it in gear. when it does idle il drive it and sometimes, not all the time, it will have trouble shifting (its an automatic. and again not all the time but sometimes it wont idle when you start it hot. im not gettin any codes. and when it does idle its around 1800 rpms, im not sure how to go about perfecting the timing and idle, so any info on that would help. i have been having some problems with vaccum hoses, and i think that may be what the cause of this is but im not sure, if you know...please let me know, cause i dont want to drive it like this and damage something else.
thanks
87 Camaro
Soon to be painted Black with chrome trim. Reborn 305 5 litre
4 bbl
pretty much stock, as of now
Old Aug 26, 2001 | 12:43 AM
Xenodrgn's Avatar
The idle problem; Vaccuum problems will definatly do it, you could also have a slow IAC (try cleaning it and it's passages).
As far as the tranny goes, try adjusting the TV cable... it could be going south...
Good luck.
Old Aug 26, 2001 | 04:34 PM
iroc5speed's Avatar
this sounds like a classic case of vacuum leaks. check to make sure all of the hoses are connected, and that you sealed the carb and intake gaskets properly.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
Old Aug 27, 2001 | 12:30 PM
senjorb0b's Avatar
well i checked all the vaccum lines,and there were two leaky ones, so the idle is good right now, i think the shifting problem is the cable that goes from the carb to the transmission. its got a kink and its bent at one spot, so hopefully that will be the end of that problem
thanks alot
87 Camaro
4 bbl
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Grant2k
Apr 4, 2016 08:21 AM
drumstixer
Sep 29, 2015 03:02 PM
AmorgetRS
Sep 28, 2015 09:33 PM
