custom CAI instructions?
Old May 29, 2005 | 10:36 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
sorry i know im supposed to search but all i found was this
http://87tagta.tripod.com/coldair.htm
and maybe im just stupid but im a little confused. my car had the emissions removed, or at least the air, what exactly does the smog canister do, and what will happen if i take it out? any loose ends i need to tie up if i remove it altogether?
anyone know of any other similar sites with directions for making one? also, whats a good air filter to use as i know a lot of you dont like k&n's?
Old May 30, 2005 | 02:02 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'll bump this for ya. K&N's are really good, I wouldn't worry about getting a better one.
Smog canister? I couldn't tell ya, maybe someone else knows...
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
dusterbd
Sep 29, 2015 08:40 AM
