People with dual roller timing chains come in
Old May 30, 2005 | 09:13 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
I just got my new motor going and i put a cloyes billet true roller timing chain on it. Didnt think about it at the time but i put it all together using the stock timing cover. Well it started grinding into the back of the timing cover because it was too thick. So we pulled it all apart and notice the stock cover was indented right where it was grinding. The 3 bolts are grinding at the cover. So we beat the timing cover back flat. Put it all back together and it didnt make any noise well a couple of days later the grinding has came back. Now sometimes it barely makes noise and other times it really squeals. So i guess i need to buy aftermarket timing cover for it. What did u guys do to get the dual roller chain to work in your car?
Old May 30, 2005 | 09:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you using a factory-style or retro-fit roller cam?
Old May 30, 2005 | 10:41 PM
formula2fast's Avatar
Car: 87 Pontiac Firebird Formula
Engine: 355 SBC-Thats all I can say or they will break my legs.
Transmission: 5 Speed
I am assuming it is not a factory roller block. Sounds like you need a cam button. Check your timing and see if it jumps around. You are most likely getting cam walk.
Old May 30, 2005 | 10:50 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have one in a solid lifter cam motor and it's fine. i also have on in a hydraulic cam motor and it's fine too with the stock timing cover. must be cam walk.
Old May 31, 2005 | 12:43 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
mine is a factory roller
Old May 31, 2005 | 01:21 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
And you're using the retaining plate, and your timing set is the one for factory roller setups?
Old May 31, 2005 | 01:23 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
i put the retaining plate back on there and the timing set is for factory roller motors
Old May 31, 2005 | 02:35 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My stock one fit just fine but when I installed a fancy chrome one the bottom gear started to eat away at the cover.
Old May 31, 2005 | 02:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Are you using a "cam bolt lock kit"?
If so, you might want to try about 3 timing cover gaskets, to space it away from the block a little bit.
Old May 31, 2005 | 06:03 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Are the aftermarket covers thicker? I went to the local parts stores and all the chrome ones were indented at the same spot my stock one was.
Old May 31, 2005 | 06:04 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
I reused the factory stuff
Vintageracer
Jan 10, 2020 05:33 PM
junkcltr
Aug 2, 2019 11:12 PM
red90IROCls1
Aug 25, 2015 06:56 AM
MY87LT
Aug 17, 2015 08:43 AM
BrianI
Aug 9, 2015 11:52 AM
