hey guys...O2 sensor "swap" question
Old Aug 26, 2001 | 06:47 PM
redhottlb9's Avatar
Tony(Fly89GTA) is having a problem gettin into closed loop,and hes throwin a few codes,unsure of what they are....one thing we want to try is replacing his O2 sensor(due to header collector gasket leak)
and we were wondering if the O2 sensor from an 86 firebird(2.8L V6) would work in his 89 L98.....let me know if it will work please
email me at REDHOTTLB9@AOL.COM
email Tony at CLARKEMUSTGONOW@AOL.COM
thanks
Andy
The "House" has spoken...
check out my my 88 WS6 Trans Am
We are the seeds of legends,our true origins are unknown...WE SIMPLY ARE...
Old Aug 27, 2001 | 12:09 AM
redhottlb9's Avatar
come on guys...simple question...
help us out here
BTTT
Old Aug 27, 2001 | 12:58 AM
Jester's Avatar
It should.
Old Aug 27, 2001 | 08:39 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by Jester:
It should.
</font>
OH NO!!!! not this answer again! Andy isn't gonna like this answer
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Aug 27, 2001 | 01:06 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
They are the same one wire o2 sensor. You can call the parts store and they both use the same o2. If you are going to buy one go ahead and change to the heated type. It will help you get into closed loop faster. Bosch p/n 13077 for 92 LT1 Vettes. The black wire is the signal wire and the two white wires are for power and ground. It doesn't matter which one you make hot or ground. Run the hot wire to the fuse block under the dash and connected it to a source that's only on when the car is running.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Aug 28, 2001 | 08:25 AM
Box of Rocks's Avatar
<font face="Verdana, Arial" size="2">Originally posted by brharris27370:
</font>
BR,
I've got a '92 LT-1 vette that is also having trouble getting into closed loop since gutting the cats and going to a Dynomax cat-back.
It smells way too rich, so I suspect the sensors are not getting hot enough to tell the ECM to go into closed mode. Open is too rich. The weird thing is that I've already replaced the stock one-wire sensors, and nobody said a word at the parts counter about a heated unit being available.
Huummmmm.......I'm on the way to Chevrolet to talk to a real parts guy - NOT friggin' Auto Zone Out.
I'll try to keep results posted, as this appears to be a problem encountered by many 3rd Genners and other bowtie owners.
Oh, fellers.....the 383 should be together in 2 weeks....and is the primary reason, along with traveling all over North America this summer, that you've not heard from me much. (I'm sure some of you like that)
I'll keep you posted.
BOR
"Yeah, just wind 'er up 'til she screams for mercy" Harrison Ford from "American Grafftti"
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
92purpz28
Aug 11, 2015 02:30 PM
squiggy2
Aug 9, 2015 09:30 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
