need some Bolt sizes (cold start inj, TPS, throttle linkage)
Old Jun 1, 2005 | 08:21 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Im puttiny my GTA back together and I lost a few bolts... I need the sizes for:
Cold start injector bolt
TPS bolt (holds tps to TB)
Throttle bracket (holds throttle/cruise cables to plenum)
Thanks.
Old Jun 1, 2005 | 07:16 PM
brutalform's Avatar
I would just check the dealer. The TPS bolts cant be had from anywhere I know of, except maybe a scrapyard. Not sure about the others though. Use a dab of antisieze on the TPS bolts. They are known for getting stripped.
Old Jun 3, 2005 | 01:28 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The throttle bracket bolts are M6X1X13.
The TPS sensor bolts are available as part of a TB screw kit from GM as part #17112369. It's about $15. Other than that I have know idea on their size.
Cold start injector bolt? I don't have the information on that one.
HTH
Old Jun 3, 2005 | 02:19 PM
brutalform's Avatar
HTH
[B]
Yea, that kit is what I bought a while back. It includes the TPS bolts, IAC housing bolts, and IIRC, the top "tuned port" plate bolts.
jklein337
Sep 19, 2018 06:23 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
