people running mini starters in here!
Old Aug 30, 2001 | 12:41 AM
87tpi420's Avatar
i have two studs and one male spade connector on my starter. the spade is oviously my ignition. but which stud do i use? there is on towards the block and on towards the pass side wheel. i bought it so long ago i dont know which wire goes where. any help would be great
thanks
gary
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Aug 30, 2001 | 02:06 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
One should be labeled "R" and the other "S"... Hook it to the S.
If they arn't labeled, I guess a little trial and error will work. I mixed them up a couple times before and it never damaged anything.
Old Aug 30, 2001 | 02:57 PM
Damon's Avatar
The S is for START and is the post towards the engine block on most mini-starters. The R is for run and is only used on older cars with points-style ignitions and resistor wires or ballast resistors for the coil. Not usually used by anything since about 1975.
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
