manifold leak
Old Aug 30, 2001 | 11:28 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
manifold leak
i was with my mechanic today and we noticed that i had coolant oozing onto my block from the manifold, and also that there was a sludgy oil residue on the block by the heads, which was smoldering and causing a little bit of smoke. we figured i have a bad manifold gasket, has anyone experienced this problem? at this point i should buy a new edelbrock performer manifold right? how much work am i looking into doing? thanks
1987 LG4 Camaro z28
Performance
KN airfilter, flowmaster 80 series and catco high flow cat, 180* thermostat
System
Panasonic CQ-DF200U deck, fosgate speakers (hpc1369, frc2246)
Old Aug 30, 2001 | 11:45 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
I take it you have the Rochester 4bbl on your Z. Replaced my OEM intake manifold on my 86Z28 with an eldebrock. Took me 3 hours. Make sure you label all the wires/hoses and vacuum pipes. It should be that hard since it is a 4bbl and not a TPI.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
tommy z-28
Oct 6, 2015 10:58 PM
bubbaz28
Sep 18, 2015 02:09 PM
bamaboy0323
Sep 12, 2015 07:14 PM
