How many fps does it take?
Old Jun 6, 2005 | 09:26 AM
ElementsofSpeed's Avatar
Car: 91 Pontiac Trans Am
My shop said that my fuel pump was bad, and i have replaced it twice in the last month. Is this possible? BTW, my fuel pump does work some of the time, can fp's cause intermittent start up problems if they are bad?
Old Jun 6, 2005 | 10:40 AM
katman's Avatar
Car: 91 Z28
Engine: 468 ci
Transmission: thm 350
I'd be looking at the fuel pump rely.
Old Jun 6, 2005 | 10:45 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, they can cause starting problems when bad. Yes, they can be intermittent about it.
When replaced, the pickup sock and in-line filter should be replaced as well.
It is also possible for other things being bad to look like a bad fuel pump, such as the aforementioned relay, as well as fuel pressure regulator, etc.
If the pump has been replaced twice within a month, either you're getting bad new pumps, or it's time to look into some other problem.
Old Jun 6, 2005 | 11:16 AM
here is what has been replaced...
fp relay
fp fuse
oil pressure sender
fuel pump twice
had steering column rebuilt for VATS
thats about it...what was happening was it would start up fine, drive for about a mile, i would then shut it off, and retry to start it up and it wouldnt start...it would crank, but not start...I think it is an ignition problem myself. Any one else? It is an intermittent problem, my car starts when it wants to. Thanks.
Old Jun 6, 2005 | 11:24 AM
Also, how do i test for spark without getting electrocutted. Thanks.
Old Jun 6, 2005 | 03:40 PM
nevermind, this shop has had my car for 3 days and have only given me a quote on my ball joints, just to be pressed in since i didnt do such a good job when i tried. then my car wouldnt start for them and they tell me its my fuel pump. So i dont know wtf is going on. how do i check for spark without frying myself.
Old Jun 6, 2005 | 04:35 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Using a Spark Plug Tester is a good safe way to check. It sure beats the housekey in the end of the wire method.
Old Jun 6, 2005 | 05:27 PM
what could cause the fuel pump to keep going bad if that is the case?
Old Jun 6, 2005 | 07:48 PM
Vader's Avatar
Ask your shop to test the fuel pump voltage as close to the pump as possible. Electric pumps are very sensitive to voltage. A little voltage drop and they aren't making adequate pressure. If the installer of the replacement pump also installed a new inlet filter and eliminated the pulsation damper, there should be no problems in the tank. Even excessive sediment shouldn't eat a pump that fast.
Check the condition of the connetor under the rear seat , the pump ground lead, the connector at the pump, the connector for the pump relay, and the fuse that supplies the pump and ECM with power.
I've had electric pumps that are almost 20 years old and have well over 180K miles on them working just fine. I've also had "pump eaters" that mysteriously needed a new pump every year - At least until the real problem in the circuit was discoverd and repaired. I had one guy bring in a '97 truck that had 120K miles and had five pumps, and he thought another was bad. My best guess is that at least 4 of those pumps were totally unnecessary. It's almost always a poor connection.
jonnyboyskate
Jun 22, 2014 08:29 AM
dhirocz
Jun 11, 2014 02:13 PM
skyhigh4by
Feb 14, 2014 12:31 PM
Anomaly
23
Nov 22, 2006 09:26 AM
