high mileage oil question
Old Jun 7, 2005 | 04:35 PM
hdtripp's Avatar
Car: 89 Formula
Engine: 5.0L tpi
Transmission: 7R400
My 305 tpi has 206k miles on it. No ring smoke, rich under acceleration, little bit of valve quide smoke after sitting. I know the end is near because the oil pressure drops dangerously low after the engine warms up at idle (less than 10 psi). Oil pressure is about 45 when I first start it, then drops off. Does anyone have a suggestion about what oil to use. I am using 10w30 pennzoil now, have used the valvoline extended life stuff before. Any other suggestions other than a rebuild. I'm trying to save enough to do a 383 swap.
Old Jun 7, 2005 | 10:07 PM
katman's Avatar
Car: 91 Z28
Engine: 468 ci
Transmission: thm 350
You might try a straight 30 weight or a 20-50. If you're not leaking or burning oil, I'd switch to synthetic to make sure you've got protection incase of very low pressure.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Exxon Limited
Aug 9, 2015 08:13 PM
