No spark no fuel comming out of injectors what's wrong?
Old Jun 7, 2005 | 11:55 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I went to start my 91 rs today and it sounds like it is about to start as it normally would. I turn the key and it sounds normal as though it is going to start but the engine will not turn all the way over (it seems to be cranking fine). I looked at the injectors on the TBI and there is no fuel sprayining from them. I then tried to start it by adding a little starter fluid into the tbi and it still would not start. I checked to see if I was getting a spark and there was none. The fuel pump does not seem to be energizing as it normally does at start up ( there is a sound kind of like a click comming from the area of the fuel pump relay when the ignition is turned forward. Any help or ideas would be appreciated.
Old Jun 8, 2005 | 06:26 AM
NML98TA's Avatar
Car: 1989 formula 350
Check your fusable link to your ECM in the engine bay close to the battery.
Old Jun 8, 2005 | 09:45 AM
drumsk's Avatar
huh?
the injectors and the spark get the signal off the coil. I also check the module in the distributor. I have had mine go and it did exactly what you are discribing. The fuel pump relay clicks when it gets the signal from the computer to run..........
Hope that helps a little
Kenny
Old Jun 8, 2005 | 10:42 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
I agree check ign module i have been through three with same symptoms.
Old Jun 8, 2005 | 11:04 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Check ignition module, pickup coil and/or ECM...
The distributor needs to send a reference pulse, generated by the pickup coil, to the ignition module, which then sends a pulse to the ECM....and the ECM fires the injectors at the appropriate time.
Good luck!
Old Jun 9, 2005 | 10:40 PM
THETANK's Avatar
Car: 91 rs
Ok thanks guys I will replace the ignition module along with the coil. anyone have any experience with this module it has a lifetime waranty and is only $30.00 ( GP Sorensen EL128). Or would it be worth investing in a preformance after market module?
http://www.partsamerica.com/ProductD...pe=194&ptset=C
Old Jun 10, 2005 | 09:38 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
That GP-Sorensen ICM will work just fine.
A word of advice, test the pick-up coil while your messing with the distributor. Once you remove the old ICM, it's really easy. The pick-up coil wiring attaches to the ICMs two-prong connector (on the top of the ICM in the picture). Take a multimeter, put it on the ohms setting, and check the resistance of the 2 wires by attaching one lead to each wire. You should see between 500 and 1500 ohms. Then, keep one lead attached to one of the pick-up coil wire and put the other lead on the distributor base, you should get infinite resistance.
And, don't forget to put the supplied dielectric grease on the distributor base in between it and the ICM.
Old Aug 6, 2005 | 02:06 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
would sort of problems might you have if the wiring/connector from the pick up coil to the ignition module is cracked or otherwise messed up? My car runs, but it idles HORRIBLY and backfired once. Never pulled distributor, but I did change cap and rotor. This was a while ago, but I THINK i noticed that the connector was bad on the pickup coil. I do check and recheck the firing order and it was fine.
Old Aug 18, 2005 | 01:03 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Thanks guys! I have an 89 Formula TBI with a "crank no start" and the ignition module was my problem... I love this board!
POZ
1992 Trans Am
May 10, 2023 07:19 PM
justin57
Aug 20, 2015 07:05 PM
Firechicken86
Aug 12, 2015 10:07 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
djmarch
Aug 9, 2015 05:27 PM
