Dang dipstick tube...
Old Jun 8, 2005 | 12:41 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Does anyone else have trouble getting a good oil reading? Everytime that I try to check my oil level it comes out with oil all over the length of the stick.
Old Jun 8, 2005 | 09:05 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
proper oil checking procedure;
1;warm engine to operating temperature
2;turn engine off and allow to sit for 1-3 minutes
3;remove dipstick and wipe with a clean shop towel(never paper)
4;insert dipstick in tube fully and remove quickly
if you still have the problem,try turning the dipstick around.you are only looking for the highest point on the stick where oil makes contact all the way across.
if that doesn't help check your pcv valve
Eric B
Old Jun 8, 2005 | 10:14 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Why never paper?
It can't be because of fiber contamination, right?
Old Jun 8, 2005 | 10:33 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I think I'll give you the benefit of the doubt since you have alot of work done that you can check your own oil level. I'm not sure how much a pipe cleaner would contaminate your oil, but I'd try someone like that. Sounds like its rubbing against the sides and leaving excess oil along the tube.
Old Jun 8, 2005 | 10:49 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Thanks Josh, yeah I know the proper way to check my oil. It will always come out with oil all over it, no matter what. I have an open element, with a breather on one side and the PCV on the other. The PCV is good, I replaced it not too long ago. I do get some "blowby" though. I don't know if my open element and breather are causing it or not.
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
NZKnight
Oct 15, 2015 02:47 PM
KCG
Sep 23, 2015 09:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
