Can smog hoses be connected straight to the cat?
Old Sep 2, 2001 | 12:28 AM
Golden80's Avatar
I was wondering if you can route the hoses from the diverter valve that go into the pipes for the exhaust manifolds to a pipe on a cat? My current LG4 does not have a pipe on the cat but my new hi-flow one does. Can you put the hoses into a "T" hose connecter and then run it straight to the cat? I don't see why not since the hoses will be providing air to the cat.
Thanks,
Matt
[This message has been edited by Golden80 (edited September 01, 2001).]
Old Sep 2, 2001 | 12:47 AM
rezinn's Avatar
Have you thought about getting a new diverter valve? Can't be too expensive, but your way would probably work the same.
Old Sep 2, 2001 | 02:15 PM
Golden80's Avatar
Where could I find a new diverter valve with one outlet? Is this something I could find at the hardware store?
Matt
Old Sep 2, 2001 | 02:19 PM
rezinn's Avatar
Lots of people remove those things, maybe you could put an ad in the classifieds to purchase one.
Wouldn't you need two outlets? One for the cat, one for the exhaust manifolds? Thats how mine is.
Old Sep 2, 2001 | 02:24 PM
Golden80's Avatar
That's what I'm trying to eliminate. I got a set of Dynomax Cerama-coats and they don't have A.I.R. fittings. I was hoping I could route both hoses to the cat. I'm also planning on putting a heated O2 sensor in the Y-pipe. The current setup has 2 hoses both running from the diverter valve into pipes on each exhaust manifold.
Thanks,
Matt
[This message has been edited by Golden80 (edited September 02, 2001).]
Old Sep 2, 2001 | 02:47 PM
rezinn's Avatar
OH! Try an auto parts store, they have a ton of connectors like that. Sorry, I thought you were trying to do something else.
onefreakz
May 14, 2018 12:15 PM
kairles
Oct 26, 2015 09:13 PM
FreeSpirit
Aug 29, 2015 05:47 PM
TheExaminer
Aug 26, 2015 04:59 PM
BurlyChev
Aug 22, 2015 01:52 PM
