Intake torquing Question
Old Jun 9, 2005 | 07:20 PM
sellmanb's Avatar
Car: '86 Berlinetta
I just got a ZZ4 intake, and right along with my other intakes for this motor, it has been impossible to attach a torque wrench to torque the bolts down in the middle of the intake, right next to the carb.
I was curious what other people did to solve this problem? I dont want to have coolant leak like a seive like it did my old intake... nor do I want to do another intake gasket swap lol.
Thanks in advanced.
Old Jun 9, 2005 | 07:30 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
I'm pretty sure those bolts are torqued to 30ft lbs. Anyone who has been around cars long enough knows what that kind of force feels like with a normal wrench. See if you can torque one of the bolts that can accept a socket. Observe how it feels. Than by hand torqing the other's using the same amount of force. "May the force be with You"
Old Jun 9, 2005 | 07:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Don't worry too much about the torque value. As long as you get them reasonably tight in the proper order nothing's going to leak, especially if you use RTV around the water jackets.
Old Jun 9, 2005 | 07:33 PM
sellmanb's Avatar
Car: '86 Berlinetta
That's basically what I did, but I felt that was pretty silly to make a 210 dollar aluminum performance intake "guessable" as to whether it would torque down properly or not. Thanks for the quick reply It made me feel better about torquing them that way lol.
Old Jun 9, 2005 | 07:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If it really worries you, you can use a crowsfoot extension on the torque wrench, but you'll have to take it into account when you set the torque.
Old Jun 9, 2005 | 07:44 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I agree. I only use my torque wrench on intake swaps because it gives me a good excuse to use it. When it comes to intakes the old saying "tight but not too tight" really applies.
Old Jun 9, 2005 | 08:09 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
a short socket and a swivel
Old Jun 9, 2005 | 08:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Using a swivel with a torque wrench is probably less accurate than not using a torque wrench at all.
Old Jun 9, 2005 | 08:20 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
yeah but if hes that worried about it the clickidy click of the torque wrench may give him peace at mind
Old Jun 12, 2005 | 04:33 PM
sellmanb's Avatar
Car: '86 Berlinetta
I'm just ****, not retarded (most the time).
I went through and torqued those hard to get to ones down.
I'm only **** about this because the last time I did an intake, it pooled coolant out of the intake, and onto my headers, giving me a nice big scare that I had a head gasket blow or something when it was coming out of my headers white.
So I went and bought a ZZ4 intake, new gasket set, and now I dont want to do another intake on the car ever again !
Thanks for the help guys.
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
