Car shifts at 2000 rpms after intake manifold swap..
Old Sep 2, 2001 | 11:59 PM
92fire-audio's Avatar
Well I finally got it running good.
Heres my only problem now, when i'm driving, it will shift at 2000 rpms and it will not downshift even when I stomp on the gas.. It feels quite sluggish because of this..
Do I just need to adjust my TV cable??
Anything else that would help this???
Old Sep 3, 2001 | 12:16 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
I believe that your T.V. needs adjusting. here is transfixleo's post on the subject.
<font face="Verdana, Arial" size="2">Originally posted by transfixleo:
This is the method: To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the D button and pull the cable casing (the black tube) back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.</font>
88' IROC-Z, 350 TPI, 700-R4
Old Sep 3, 2001 | 03:09 PM
iroc5speed's Avatar
if it feels sluggish, it may be due to a vacuum leak, I would check for that too, because that's a common problem.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Sep 3, 2001 | 05:46 PM
It was the TV cable.. It just felt sluggish because it would never downshift into the lower gear... Its fast as ever now though...
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
mustangman65_79
Aug 8, 2015 12:07 PM
