Bent Pressure plate?????
Old Jun 10, 2005 | 07:27 PM
andys86ta's Avatar
Car: 1986 trans am
Engine: 300hp 355cu. inch
Transmission: 350 turbo with shift kit and ratchet shifter
I am going crazy here. I boiught an 86 transam for parts with a "perfect" 5 speed and i wanted to put it in my 86 transam to replace the auto. After evrything was swapped, i noticed a vibration starting at 2000 rpm and increasing with engine speed. This is a "new" clutch, pressure plate and bearing in the donor car for about a month. It actually does look pretty new. my first assumpsion was the fly wheel was warped. put a new one in. started the engine with only the flywheel bolted on no tranny or clutch ***. Smooth as a caddilac. Problem solved? No. reassembled the tranny into the car and still a vibration with the car stopped, in neutral and the clutch pedal to the floor. The pedal feels a little chattery when releasing it in gear to take off. I know this is a novel but there are most of the details Please any suggestions.
Old Jun 10, 2005 | 08:29 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
did you put a pilot bearing/bushing in the end of your crank when you did the swap?
Old Jun 11, 2005 | 05:33 AM
ede's Avatar
ede
who'd of thought of that. that was going to be my question until i read your reply.
Old Jun 11, 2005 | 06:05 AM
andys86ta's Avatar
Car: 1986 trans am
Yeah. a brass pilot bearing was already in the crankshaft.
Old Jun 11, 2005 | 06:12 AM
ede's Avatar
ede
you don't know if the problem existed or not in the other car before you swapped the partsd over do you?
Old Jun 11, 2005 | 11:57 AM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
alright, but unless this motor has had a standard trans on it before or atleast the crank your using was once used with a stick it shouldn't of had one so you are sure? just checkin
Old Jun 11, 2005 | 08:43 PM
andys86ta's Avatar
Car: 1986 trans am
Okay here is a bit more info. The donor car is an original 305 ho 5 speed, the car I drive is a built up 350 with nothing origional in it. I asked around home here a bit and two people have told me to try the 305 harmonic balancer on my 350. Are there any balancing changes gm made i need to know about? i am 99.9% sure a 305 and a 350 crank are the same-at least up to 1987.
Help me!!
Old Jun 11, 2005 | 08:44 PM
andys86ta's Avatar
Car: 1986 trans am
The crankshaft i bout fromthe machine shop and it must have been in a stick car before trade in.
morrow
Jan 13, 2024 12:29 PM
Fronzizzle
Mar 18, 2019 08:29 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
someone972
Aug 30, 2015 12:52 AM
