replaced heater core. Now have overheating problems!!
Old Sep 4, 2001 | 09:13 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
i replaced my heater core and now my car gets really hot like over 220. when i am stop for a light it gets to like 240. the fan is on and everything. I heard that if you have an air bubble in the system from when i put the heater core in and then the air is stuck in there. because the coolant went into the heater core and pushed the air out and now it just going around. has anyone everyheard of this? anyone have any ideas?
Old Sep 4, 2001 | 09:30 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
is it possible i mixed up the heater hoses? i don't think i did but would that cause it to get hot fast?
Old Sep 4, 2001 | 11:32 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Its possible that reversed hoses going into the core could screw things up, but I doubt it. Just bypass the heater core to test your theory. Make sure you have enough liquids in your radiator and check for other leaks first.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Sep 4, 2001 | 12:46 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
First off i had the heater core bypassed and the car ran like normal temp. replaced the core on sat. the car battery died so i jumped it and let it run for like 20 mintues and it stayed around 220 usually when it sits is when it gets real hot. anyway go driving yesterday and it will run cool in 4ht gear. but when at a light or stop for a brief second it gets way over 220. also when i have the heat on the temp will stay down.
any ideas???
Old Sep 4, 2001 | 01:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's a restricted radiator...
The heater core "bypasses" the radiator. That is, it is in parallel with the rad. The hot coolant coming out of the top of the motor has a choice; it can either go to the heater core, or it can go to the radiator; it will of course go whichever way is the path of least resistance. With no heater core, it was all forced to go through the rad, but now apparently the heater core is so much more free-flowing that a significant portion of the fluid goes that way, doesn't get cooled, and returns to the block intake still hot.
Sounds like you need a new radiator, or at least some service to the one you have.
ICON Motorsports
Old Sep 4, 2001 | 01:33 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
so how would i go about fixing this without buying a new radiator? my car worked fine before with the old radiatior. it really didn't get that hot. with the new one my car gets really hot.
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Fronzizzle
Aug 9, 2015 01:15 PM
